Building a custom DLL from the command line for an old IPP distribution
georgiswan
I am trying to build a custom IPP DLL with the command line tool  ipp_custom_library_tool .
I have    compilers_and_libraries_2018  installed  and I find the custom library  tool in   /opt/intel/ipp/tools/custom_library_tool .
I have created a file with the list of needed symbols and they are recognized by the tool.
My problem is that we actually link with and use and old  IPP ( composer_xe_2015.7.234 )  but we compile with 2018. The custom_library_tool does not exist (to my knowledge) in that old 2015 distribution and when I use the -c option of custom_library_tool  to point to the old distribution, I get an error:
    Error: Compilers and Libraries files aren't found
If I dont use -c, the tool completes but warns about many not found symbols that exist in 2015.7  but do not anymore in 2018 (ex: ippiErode3x3_32f_C3IR ).
Is it possible to build a custom library from an old IPP distribution ?
Gilbert
georgiswan
I thought I would add some more precise details in hope to get some reply.
I created the list of ipp symbols used in my dylib (Mac OS) with:
nm libMylib.dylib |grep 'U _ipp'| sed -E 's/^[ ]+U _(.+)$/\1/' > /tmp/ippFuncs.txt
Then I went to the custom_library_tool :
cd /opt/intel/compilers_and_libraries_2018.1.126/mac/ipp/tools/custom_library_tool
and I tried to create a custom library with:
./ipp_custom_library_tool  -n libMyCustLib -l /tmp/ippFuncs.txt  -o /tmp/ipp_customs/ -intel64  -macos
I got many warnings for missing symbols:
Warning: ippiCrossCorrSame_NormLevel_32f_C1R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_32f_C3R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_32f_C4R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u32f_C1R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u32f_C3R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u32f_C4R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u_C1RSfs doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u_C3RSfs doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_NormLevel_8u_C4RSfs doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_Norm_32f_C1R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_Norm_32f_C3R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_Norm_32f_C4R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_Norm_8u32f_C1R doesn't match with any Intel(R) IPP function
Warning: ippiCrossCorrSame_Norm_8u32f_C3R doesn't match with any Intel(R) IPP function
This is because my libMylib.dylib is linked against ipp2015.7  but the ipp_custom_library_tool seems to want to use the 2018 IPP libraries to build the custom library.
Any hint on possibly building a custom library for the 2015.7 (or any older IPP libraries) ?
georgiswan
Another question regarding the ipp_custom_library_tool,  will such a custom library contain the symbols for all architectures ?
For example, if my library needs   ippsSet_16s   will I get it for e9, g9, m7, mx, p8, .  So that my custom library can be used to build an application that could run on any architecture ?
Chao_Y_Intel
These two functions was deprecated in the old release, and not included in the latest pacakge:
Could you use the following new functions to replace the old one?
ippiCrossCorrSame_NormLevel_32f_C1R   ippiCrossCorrNorm_32f_C1R+algType=ippiROISame|ippiNormCoefficient
ippiCrossCorrSame_Norm_32f_C1R           ippiCrossCorrNorm_32f_C1R+algType=ippiROISame|ippiNorm
yes, it is right.  ipp_custom_library_tool build the library for multiple processors, and it will do the runtime dispatch for your code.
Chao
