Calculate PSNR in MPEG-4
transcoding
Hello guys,
I need to calculate the PSNR in MPEG-4 v5.3 because there's no metric that's implemented under IPP MPEG-4.
Have anyone tried before to do this? Do you have any idea?
BR,
Chao_Y_Intel
The easy way is to decode the bit stream from the encoder's output, then calculate each frame difference with original YUV data.
NormDiff_L2, and NormDiff_L1 may help to calculate the difference.
Chao
transcoding
To my knowledge, there's only H.264 decoder in IPP v5.3. Am I right?
Please, can you give me an example of how can I use NormDiff_L2? Is it a function?
Thank you!
transcoding
I agree with you when you say that NormDiff_L2 and NormDiff_L2 and NormDiff_L1 may help, but the problem is that none of the functions TransMacroBlockIntra_MPEG4 or TransMacroBlockInter_MPEG4 is called!!!
What do you suggest plese?
Chao_Y_Intel
MPEG4 decoder is included UMC sample code. You can use sample to decode the video.
NormDiff_L2 and NormDiff_L2 and NormDiff_L1 are used for computing PNSR of two decoded videos.
Chao
transcoding
Quoting - Chao Y (Intel)
I found that we can call MPEG4 decoder only using simple_player. Is that what you're talking about?
Can you give me an example of how can I use NormDiff_L2? It's not clear for me.
Thank you!
Chao_Y_Intel
yes, simpleplayer can be used to decode the MPEG4 stream.
ippiNormDiff_L2 usage, could you check "Example 11-11 Using the function ippiNormDiff_L1" in IPP manual. The usage of NormDiff_L2 and NormDiff_L1 is same except that they return difference norm result.
Chao
