6814 Discussions
Can IPP be used in an embedded PC with RTEMS as realtime OS
hnhoan
I'd like to know if it is possible to us IPP with RTEMS in an embedded PC. Is a port possible.
Intel_C_Intel
The strictly official answer isyou can look on the list of supported OS in IPP documentation.
But, one of the requirement for IPP development is minimization of operating system dependancy. Because of that, it is possible to use IPP for example in kernel mode drivers. Not DLL of course but static libraries.
We do not test IPP on RTOS, embedded system and other staff like that, but you can try to use it here. I think, technically itmight bepossible.
By the way, if you are interested in full support for embedded system in IPP it would be better to submit it as a feature requeston technical support channel.
Vladimir
