6814 Discussions
Can i use ipp achieve a image overlay another image 's special region (The iamge is YV12)
zac_2000
The is Image 1
|AAAAAAAA |
|A|
The Dest Image can be
|AAAAAAAA |
It Can't paste image.I only use this;
Thanks in advance.
Vladimir_Dudnik
Do you want to copy one image (say some small sprite) into another image (say, bigger, for example background)?
Vladimir
zac_2000
Yes.The Image is YV12 PixelFormat.
Vladimir_Dudnik
We do not have such a special variant of IPP function, but you should be able to use just ordinary ippiCopy function, just need to determine correct sizes of data chunks
Vladimir
zac_2000
Y = 0.257*R' + 0.504*G' + 0.098*B' + 16
Cb = -0.148*R' - 0.291*G' + 0.439*B' + 128
Cr = 0.439*R' - 0.368*G' - 0.071*B' + 128
Image1 is only character'A' ( Color is Red) BackGroud color is Black.
I make Image2's correspounding position value is Image1's.
I found In Character'A' area, there is not only red, but some transparent.
I thinkthe wrong maybe the Cb,Cr use by 4 pixels.I Set the value is( -0.148*255 + 128, 0.439*255 + 128).
I use rgb565 is right,but itexhaust more time!
My English is poor, my description may be no clear!
Thanks in advance!
Vladimir_Dudnik
We do not have copy function for RGB565 data, but if you use RGB24 it is possible to copy small image into arbitrary point of another image.
Vladimir
