Compiling only necessary functions into a static library
Kevin_S_2
I'm trying to build a static library of video decoding functions, based on the IPP high-level API samples, for use in another application. When I include ippi_l.lib as a dependency of this library, it swells to over 100 MB in size, but when I compile the actual application using the library, it comes out to only about 10 MB total. Since I'm sure not everything in the ippi library is necessary for my static library, is there any way to signal the compiler to include only what it needs?
I'm using Visual Studio 2010 with Intel C++ Composer 2013 update 1. Any help would be appreciated.
Thanks in advance,
Kevin Scannell
Chuck_De_Sylva
Kevin, Which version of IPP are you using? - Chuck
Kevin_S_2
IPP version 7.1 update 1. -Kevin
SergeyKostrov
Valued Contributor II
>>...When I include ippi_l.lib as a dependency of this library, it swells to over 100 MB in size... About 4 or 6 months ago, or so, there was a post describing a similar case and I remember that it was added to a bug report. >>...IPP version 7.1 update 1... It is clear that in IPP version 7.1 Update 1 the problem wasn't fixed. Could somebody from IPP team clarify the situation?
Sergey_K_Intel
Hi Kevin, What do you mean by term "build a static library"? How another binary library (ippi_l in your case) could be a dependant? Static library is a collection (archive) of object modules compiled from some language source files. The libraries - .lib files - don't take part in compilation process. Regards, Sergey
SergeyKostrov
This is a follow up. >>...When I include ippi_l.lib as a dependency of this library, it swells to over 100 MB in size, but when I compile the actual >>application using the library, it comes out to only about 10 MB total... Hi Kevin, Did you manage to resolve the problem? Please let us know. Best regards, Sergey
SergeyKostrov
Please try /OPT:REF linker option since it will eliminate all unreferenced data.
