Converting from ippiHistogramEven (IPP 7.0) to ippiHistogram (IPP 2017)
Shai_E_
I'm converting the use of IPP 7.0 to IPP 2017.
I have an issue that ippiHistogram does not produce the same result as ippiHistogramEven.
The levels that ippiHistogramUniformInit generate are different then the levels generated by ippiHistogramEven in IPP 7.0.
Thanks!
Zhen_Z_Intel
Hi Shai,
I think the result of IPP2017 is more reasonable, for instance, the 10th value should be 65535/20*9=29490.75, IPP2017 adopts truncation, thus, the value is assumed as 29490. However IPP7 gives value 29493. I think the result of IPP 2017 should be acceptable, but IPP7 is not reliable. I think we already fixed problem in IPP7 and the result of IPP2017 is correct.
Fiona
Zhen_Z_Intel
Hi Shai,
Could you provide a simple test case to reproduce this problem? Also please provide more version info about IPP 2017, is it gold release or update version? Thanks, I am looking forward your reply.
Fiona
Shai_E_
Hi Fiona,
The following code on IPP 7.0:
    const int HEIGHT = 8;
    const int WIDTH = 8;
    Ipp8u pImg[WIDTH*HEIGHT];
    IppiSize roi = { WIDTH, HEIGHT };
    int i;
    IppStatus sts;
    IppsRandUniState_8u* pRUS;
    sts = ippsRandUniformInitAlloc_8u(&pRUS, 0/*low*/, 255/*high*/, 0/*seed*/);
    sts = ippsRandUniform_8u(pImg, WIDTH*HEIGHT, pRUS);
    const int nBins = 20;
    int nLevels[] = { nBins + 1 };
    Ipp32f lowerLevel[] = { 0 };
    Ipp32f upperLevel[] = { USHRT_MAX };
    Ipp32s pLevels[nBins + 1], *ppLevels[1];
    int sizeHistObj, sizeBuffer;
    Ipp8u* pBuffer;
    Ipp32s pHistVec[nBins];
    // calculate histogram
    sts = ippiHistogramEven_8u_C1R(pImg, WIDTH, roi, pHistVec, pLevels, nBins + 1, 0, USHRT_MAX);
    for (auto level : pLevels)
        std::cout << level << " ";
and the following code on IPP 2017 Update 3:
    int i;
    IppStatus sts;
    const IppLibraryVersion *pp = ippiGetLibVersion();
    IppsRandUniState_8u* pRndObj;
    int sizeRndObj;
    // get spec size
    ippsRandUniformGetSize_8u(&sizeRndObj);
    pRndObj = (IppsRandUniState_8u*)ippsMalloc_8u(sizeRndObj);
    // initialize rnd spec
    ippsRandUniformInit_8u(pRndObj, 0/*low*/, 255/*high*/, 0/*seed*/);
    // fill image
    for (i = 0; i < HEIGHT; i++) {
        sts = ippsRandUniform_8u(pImg + i*WIDTH, WIDTH, pRndObj);
    ippsFree(pRndObj);
    Ipp32f pLevels[nBins + 1], *ppLevels[1];
    IppiHistogramSpec* pHistObj;
    Ipp8u* pBuffer;
    Ipp32u pHistVec[nBins];
    // get sizes for spec and buffer
    ippiHistogramGetBufferSize(ipp8u, roi, nLevels, 1/*nChan*/, 1/*uniform*/, &sizeHistObj,
        &sizeBuffer);
    pHistObj = (IppiHistogramSpec*)ippsMalloc_8u(sizeHistObj);
    pBuffer = (Ipp8u*)ippsMalloc_8u(sizeBuffer);
    // initialize spec
    ippiHistogramUniformInit(ipp8u, lowerLevel, upperLevel, nLevels, 1, pHistObj);
    // check levels of bins
    ppLevels[0] = pLevels;
    sts = ippiHistogramGetLevels(pHistObj, ppLevels);
The levels computed in IPP 7.0 are:
0 3277 6554 9831 13108 16385 19662 22939 26216 29493 32770 36047 39324 42601 45878 49155 52431 55707 58983 62259 65535
and on IPP 2017 :
0 3276 6553 9830 13107 16383 19660 22937 26214 29490 32767 36044 39321 42597 45874 49151 52428 55704 58981 62258 65535
As you can see, the levels are different, I would expect them to be the same.
Shai
Zhen_Z_Intel
Hi Shai,
Seems we changed rounding of calculation pLevel to truncation. I will check with developing team, thanks.
Fiona
Zhen_Z_Intel
Hi Shai,
Fiona
