I have implemented a video export function writing H.264 encoded video to an MPEG 4 container using the UMC classes from IPP 6.1.
The resulting video (example attached) plays fine in VLC, but in QuickTime player (on Mac) the frames jump around as though they have been re ordered.
Here is the relevant code. The parameters I use for the codec came from the umc_video_enc_con sample.
Any suggestions?
void CMovieExport::ExportFrames(const QValueVector<AnimData> &anims, const QString &movieName, CProgressReporter &pr) const
QString curFrameName;
CPtr<CCanvasU8> curFrameCanvas;
for (unsigned a = 0, an = anims.size(); a != an; ++a)
if (anims.size())
curFrameName = anims[0].first;
break;
if (curFrameName.isEmpty())
throw "No files";
curFrameCanvas.Reset(CCanvasLoader::Instance()->LoadU8(curFrameName));
if (!curFrameCanvas)
throw "Frame Failed";
unsigned int width = curFrameCanvas->Width();
unsigned int height = curFrameCanvas->Height();
.size();
UMC::Status status;
UMC::MediaData DataOut;
UMC::VideoData DataIn;
UMC::H264EncoderParams Params;
UMC::H264VideoEncoder H264Encoder;
UMC::MP4Muxer Muxer;
UMC::MuxerParams MuxerParams;
UMC::VideoStreamInfo VideoInfo;
UMC::FileWriter Writer; UMC::FileWriterParams WriterParams;
s...
.size(); curFrame < numFrames; ++curFrame)
FrameData curFrameData = anims[curFrame];
curFrameCanvas.Reset(CCanvasLoader::Instance()->LoadU8(curFrameData.first));
continue;
nRequestedFrames++;
// Convert to YUV 420
curFrameCanvas->ExportYUV420Data(cYUVData, MAXYUVSIZE);
void SetNiceH264Params(UMC::H264EncoderParams &p)
p.key_frame_controls.method = UMC::H264_KFCM_INTERVAL;
p.key_frame_controls.interval = 200;
p.key_frame_controls.idr_interval = 1;
p.B_frame_rate = 3;
p.treat_B_as_reference = 1;
p.num_ref_frames = 4;
p.num_ref_to_start_code_B_slice = 1;
p.num_slices = 0; // Autoselect
p.profile_idc = UMC::H264_HIGH_PROFILE;
p.level_idc = 0; //Autoselect
p.chroma_format_idc = 1; // YUV 420.
p.bit_depth_luma = 8;
p.bit_depth_chroma = 8;
p.aux_format_idc = 0;
p.bit_depth_aux = 8;
p.alpha_incr_flag = 0;
p.alpha_opaque_value = 0;
p.alpha_transparent_value = 0;
p.rate_controls.method = UMC::H264_RCM_VBR;
p.rate_controls.quantI = 0;
p.rate_controls.quantP = 0;
p.rate_controls.quantB = 0;
p.info.bitrate = 1000000;
p.mv_search_method = 2;
p.me_split_mode = 1;
p.me_search_x = 8;
p.me_search_y = 8;
p.use_weighted_pred = 0;
p.use_weighted_bipred = 0;
p.use_implicit_weighted_bipred = 0;
p.direct_pred_mode = 1;
p.use_direct_inference = 0;
p.deblocking_filter_idc = 0; // 0 is "on". 1 - "off"
p.deblocking_filter_alpha = 0;
p.deblocking_filter_beta = 0;
p.transform_8x8_mode_flag = 1;
p.use_default_scaling_matrix = 0;
p.qpprime_y_zero_transform_bypass_flag =0;
p.entropy_coding_mode = 1;
p.cabac_init_idc = 2;
p.coding_type = 0;
p.numFramesToEncode = 0;
p.m_QualitySpeed = 1;
p.quant_opt_level = 0;
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
