Heap corruption in ippiWarpPerspectiveLinear_8u_C1R
Aleksandr_B_
Hello.
It seems the ipp 2018.3.210 contains a bug in the ippiWarpPerspectiveLinear_8u_C1R function.
The following sequence of code generates exception (Unhandled exception at 0x776DE9A3 (ntdll.dll) in blabla.exe: 0xC0000374: A heap has been corrupted (parameters: 0x77714270).) after last function call (all params are correct and the resulting image is also ok):
	int specSize, buffSize;
	ippCheck(ippiWarpQuadGetSize(
		IppiSize(src.size()), srcQuad,
		IppiSize(dst.size()), dstQuad,
		ippWarpPerspective, ipp8u, ippLinear, ippBorderTransp,
		&specSize, &buffSize));
	IppBuff<IppiWarpSpec> spec(specSize);
	ippCheck(ippiWarpQuadLinearInit(
		ippWarpPerspective, ipp8u, 1, ippBorderTransp, 0, 0,
		spec.ptr()));
	IppBuff<Ipp8u> buffer(buffSize);
	ippCheck(ippiWarpPerspectiveLinear_8u_C1R(
		src.ptr(), (int)src.step,
		dst.ptr(), (int)dst.step, IppiPoint(), IppiSize(dst.size()),
		spec.ptr(), buffer.ptr()));
Pavel_B_Intel1
thank for the report, will investigate and report about results.
Pavel
Aleksandr_B_
update:
I use 32 bit static libraries.
I've checked versions 2017.1.143 and 2017.4.210 - all the same.
ippiWarpAffineLinear_8u_C1R works fine.
OS Windows 7 (x64), Visual Studio 2015.
P.S. IppBuff<> is my wrapper around ippMalloc / ippFree; ippCheck() just checks the function return values.
Tatyana_B_Intel
Hi Alexander,
Could you please provide the simple reproducer with actual parameters values? Or at least image sizes.
Tatyana
Aleksandr_B_
source image size: 438 x 270
destination image size: 768 x 160
source quadrangle is convex and about  270 x 100 inside source image
destination quadrangle is the whole destination image.
Aleksandr_B_
ok,
I've added a couple of lines and made up VS2015 solution reproducing the bug (see attachment)
Tatyana_B_Intel
Thanks a lot for the reproducer. I'll check this and will back to you. Best regards, Tatyana
Tatyana_B_Intel
Alexander,
I've checked your reproducer and found that you missed ippiWarpGetBufferSize usage for defining the size of buffer for ippiWarpPerspectiveLinear_8u_C1R.
Please see an example here: https://software.intel.com/en-us/ipp-dev-reference-warpquadnearestinit-sample
And the documentation for ippiWarpPerspectiveLinear https://software.intel.com/en-us/ipp-dev-reference-warpperspectivelinear
Also please find the fixed version of your example:
#include <ipp.h>
#include <vector>
#include <iostream>
#include <Windows.h>
class HeapChecker
private:
	void check() const {_heapchk();}
public:
	explicit HeapChecker() {check();}
	~HeapChecker() {check();}
int main()
	const int srcW = 438, srcH = 270, dstW = 768, dstH = 160;
	std::vector<Ipp8u> src(srcW * srcH);
	std::vector<Ipp8u> dst(dstW * dstH);
	double srcQuad[4][2] = {{82., 140.}, {355., 134.}, {352., 221.}, {82., 218.}};
	double dstQuad[4][2] = {{0., 0.}, {767., 0.}, {767., 159.}, {0., 159.}};
	IppStatus sts = ippStsNoErr;
	sts = ippiWarpQuadGetSize(
		IppiSize{srcW, srcH}, srcQuad,
		IppiSize{dstW, dstH}, dstQuad,
		&specSize, &buffSize);
	IppiWarpSpec *spec = (IppiWarpSpec*)ippsMalloc_8u(specSize);
	sts = ippiWarpQuadLinearInit(
		spec);
	sts = ippiWarpGetBufferSize(spec, IppiSize{ dstW, dstH }, &buffSize);
	Ipp8u *buffer = ippsMalloc_8u(buffSize);
		HeapChecker heap_checker;
		sts = ippiWarpPerspectiveLinear_8u_C1R(
			src.data(), srcW,
			dst.data(), dstW, IppiPoint(), IppiSize{dstW, dstH},
			spec, buffer);
	std::cout << "I'm happy if you see this";
	ippFree(spec);
	ippFree(buffer);
Tatyana
Aleksandr_B_
Thank very much you for your assistance.
Yes, it was my fault.
P.S. In my defence I'd like to say that the functions call logic seems to me rather weird: why do we need to submit &buffSize at the ippiWarpQuadGetSize function call if the real buffer size is calculated by another function - ippiWarpGetBufferSize ?
Tatyana_B_Intel
Alexander,
ippiWarpQuadGetSize calculates buffer size for Init functions. In case of Linear interpolation additional buffer is not required. But in case of Cubic one you can see the last parameter - Init Buffer (https://software.intel.com/en-us/ipp-dev-reference-warpperspectivecubicinit).
So it was introduced 1 API to cover all possible cases of interpolations.
Tatyana
