6825 Discussions
Help with function ippiYCbCr422ToYCbCr420_8u_C2P3R
gjackson2434
I need help using this function. My input and output types is LPBYTE. How do I convert it to be used in this function ippiYCbCr422ToYCbCr420_8u_C2P3R?
My image is YUY2 and I am trying to convert it to I420.
When I try it I get unable to reading memory 0x00000000.
Sample code using the IPP would be very helpfully.
jere_jones1
While I am not experienced with that specific function, I have encountered the reading memory at 0x00000000. It is the result of trying to use a null pointer.
Have you tested the return code from the function? If it returns ippStsNullPtrError then you are passing it a null pointer.
Jere
gjackson2434
Here is the sample code I am using. Please help.
LPBYTE ImageI420[3];
IppiSize RoiSize;
ImageI420[0] = (LPBYTE)
new unsigned char[dwWidth * dwHeight * 3];
ImageI420[1] = (LPBYTE)
ImageI420[2] = (LPBYTE)
RoiSize.height = dwHeight * 2;
RoiSize.width = dwWidth * 2;
ippiYCbCr422ToYCbCr420_8u_C2P3R(RawImageAddr,0,ImageI420,0,RoiSize);
RawImageAddr is a YUY2 image in LPBYTE type.
gjackson2434
Here is my new code please someone help
int
dstStep[3];
IppiSize RoiSize;
dstStep[0] = dwWidth * dwHeight *
sizeof(ImageI420);
dstStep[1] = dwWidth * dwHeight *
sizeof(ImageI420);
dstStep[2] = dwWidth * dwHeight *
sizeof(ImageI420);
ippiYCbCr422ToYCbCr420_8u_C2P3R(RawImageAddr,dwWidth * dwHeight *
sizeof(RawImageAddr),ImageI420,dstStep,RoiSize);
Vladimir_Dudnik
there is piece of code from our expert, hope it will help
Ipp8u* ImageI420[3];
int stepI420[3];
Ipp8u* ImageYUY2;
int stepYUY2;
IppiSize roiSize = { 1024, 768};
ImageI420[0] = ippiMalloc_8u_C1( roiSize.width, roiSize.height, &(stepI420[0]));
ImageI420[1] = ippiMalloc_8u_C1( roiSize.width, roiSize.height, &(stepI420[1]));
ImageI420[2] = ippiMalloc_8u_C1( roiSize.width, roiSize.height, &(stepI420[2]));
ImageYUY2 = ippiMalloc_8u_C2( roiSize.width, roiSize.height, &stepYUY2 );
ippiYCbCr422ToYCbCr420_8u_C2P3R( ImageYUY2, stepYUY2, ImageI420, stepI420, roiSize);
ippiFree(ImageI420[0]);
ippiFree(ImageI420[1]);
ippiFree(ImageI420[2]);
ippiFree(ImageYUY2);
Vladimir
