How to debug the ipp-samples in vs 2005.net?
jilljilljill
Hi, I am a user of IPP
I want to test some new algorithms in H.264, and I use the ipp-samples\audio-video-codecs as my platform. I have built and run the IPP lib success. And encode *.yuv files to *.264 files through umc_video_enc_con.exe success.
But if I modified the some codes in files in h264_enc\src, I had to run build32.bat to build all the files in ipp-samples\audio-video-codecs. It waste many time somewhat.
So, I begin to build a project in vs2005.net, and want to debug the files through vs2005.net. But there are many link errors, such as
public: __thiscall UMC::BaseCodec::BaseCodec(void)" (??0BaseCodec@UMC@@QAE@XZ) and many other link errors including error LNK2001 error LNK2019 error LNK2010
Therefore, could you give me some suggestions howto build and debugfiles inipp-samples\audio-video-codecs in vs2005.net ?
Thanks a lot.
pushkar_p
Quoting - jilljilljill
I want to test some new algorithms in H.264, and I use the ipp-samplesaudio-video-codecs as my platform. I have built and run the IPP lib success. And encode *.yuv files to *.264 files through umc_video_enc_con.exe success.
But if I modified the some codes in files in h264_encsrc, I had to run build32.bat to build all the files in ipp-samplesaudio-video-codecs. It waste many time somewhat.
Therefore, could you give me some suggestions howto build and debugfiles inipp-samplesaudio-video-codecs in vs2005.net ?
Thanks a lot.
pushkar_p
Thanks a lot.
I have built the simple player in VS 2008. I mean I don't use the make file and batch files provided by IPP. I created the solution from scratch. It includes the audio video codecs. If you want I can post it here?
pushkar
jilljilljill
Dear pushkar,
Thank you very very much. I am eager to learn it. Please post it here.
Nice to meet you.
Yours
jill
pushkar_p
Dear pushkar,
Nice to meet you.
Yours
jill
Hello Jill,
I am attaching the simple player solution and 5 project files of Visual Studio 2008. I am not sure if they are compatible with VS 2005. I am purposely not attaching the source code files since you must have it already. My project was build with IPP 5.3.083.
When you open the solution in VS you will see the files that it's missing and you can add them from your computer.
pushkar
jilljilljill
Quoting - pushkar_p
Hello Jill,
pushkar
Dear pushkar,
OK, thanks a lot. But where is the attachment?
if you do not mind, could you send the files directly to my email: ?
very very thanks.
Yours jill
Chao_Y_Intel
Jill,
You can check the latest IPP 6.0 release and audio and video Codec sample. IPP 6.0 sample includes the vs. 2005.net for audio-video-codecs samples
Chao
jilljilljill
Dear Chao,
OK, Thanks a lot, I will try.
Nice to meet you.
Yours,
Jill
Sergey_K_Intel
Hi, Buildxx.bat files usually contain two successive "nmake..." lines. The first line does clean-up of sample workspace, i.e. deletes all objects and executables. You may comment the first nmake line out and build.bat will behave like ordinary make, so it will rebuild what is necessary only. Or, you might have already done that?
mintsu
Hi Pushkar,
I would appreciate if you posted your solution for building in VS2008.
Mintsu
Quoting - pushkar_p
pushkar
Chao_Y_Intel
The sample is built with 2005. It is expected to work with VS 2008 (VS 2005 can automatically conert the projects).
Did you get any problem on this?
Chao
Heidarian
Quoting - pushkar_p
pushkar
Dear friends
I got the same errors as jilljilljill (linker errors).
Do anyone have Pushkar's project? I can not fine the attached files?
Chao_Y_Intel
Hi Heidarian,
IPP UMC smaple code include project files in the currect release. For example, for simpleplayer applicaiton, you can find the solution files at:
ipp-samplesaudio-video-codecsapplicationsimple_player
Can it work for you?
Chao
Heidarian
Quoting - Chao Y (Intel)
Hi Heidarian,
Chao
Dear Chao
I tried to build simpleplayer,but I got following errors:
2>c:ipp-samplesaudio-video-codecsioaudio_rendersincludedsound_buf.h(16) : fatal error C1083: Cannot open include file: 'dsound.h': No such file or directory
2>directsound_render.cpp
1>c:ipp-samplesaudio-video-codecsioaudio_rendersincludedirectsound_render.h(18) : fatal error C1083: Cannot open include file: 'dsound.h': No such file or directory
1>Build log was saved at "file://c:ipp-samplesaudio-video-codecs_binWin32debug_asciiumc_pipelineBuildLog.htm"
1>umc_pipeline - 1 error(s), 0 warning(s)
2>c:ipp-samplesaudio-video-codecsioaudio_rendersincludedirectsound_render.h(18) : fatal error C1083: Cannot open include file: 'dsound.h': No such file or directory
2>Generating Code...
2>Build log was saved at "file://c:ipp-samplesaudio-video-codecs_binWin32debug_asciiaudio_rendersBuildLog.htm"
2>audio_renders - 2 error(s), 0 warning(s)
3>------ Build started: Project: simple_player, Configuration: debug_ascii Win32 ------
3>Linking...
3>LINK : fatal error LNK1104: cannot open file '...._binwin32debug_asciiaudio_rendersaudio_renders.lib'
I searched ipp-samples directory,but could not find dsound.h and audio_renders.lib.
There was not any more error and all other files complied correctly.
I do not know what is the problem!
Ying_H_Intel
Dear heidarian,
Have youone Microsoft* DirectX* SDK version installed on your machine? Theaudio-video-codec sampe requiretheSDK. Please see the software requirement as below (and the file "dsound.h"isfrom it)
Software requirements:
  • Intel IPP for Windows* version 6.1
  • Intel C++ Compiler for Windows*: version 10.1, 11.0, or 11.1
  • Intel Parallel Composer
  • Microsoft* Windows* Vista, Microsoft* Windows* XP, Microsoft* Windows* 2003 Server, or Microsoft* Windows* 2008 Server
  • Microsoft* DirectX*: 9.0 SDK Update (August 2008)
  • Microsoft* Visual C++* 2003, Microsoft* Visual C++* 2005, Microsoft* Visual C++* 2008
    • When building for a Intel Xeon processor with Intel EM64T, the Microsoft* EM64T Platform SDK is required
Ying
Heidarian
Quoting - Ying Hu (Intel)
Dear heidarian,
Have you one Microsoft* DirectX* SDK version installed on your machine? The audio-video-codec sampe require the SDK. Please see the software requirement as below (and the file "dsound.h" is from it)
Ying
Dear Ying
Thanks very much, I installed DirectX SDK, and the problem resolved.
