How to render a video for simple player
danielwang1971
I have a H264 compession raw video sream file. I want or reander it in Simple player but didn't work.
For DirextX(-vdx):
Video Render : DX
-RenderFormat: YV12
Stream Type : H264PV
Video Info :
-Video Type : H264
-Resolution : 704x480
-Frame Rate : 30.00
DecRate:257.18 fps(Dec 2.98ms/f + Conv 0.90ms/f = 3.89ms/f) RndrRate 0.00fps Aud io Dec 0.00chnls
And then Bloacked.
For GDI(-vgdi):
Video Render : NULL
Not image displayed.
Could you tell me what the problem?
Daniel wang
Vladimir_Dudnik
We do support H.264 compression/decompression in IPP, do not support H.265
Vladimir
danielwang1971
Sorry, it's my mistake.I meansH264 not H265.
Daniel wang
danielwang1971
I have sovle the problm DX rendeting didn't work in Vista.
The problem is caused by Desktop Window Manager, which is responsible for compositing under Vista.It expects applications to draw themselves into an off-screen surface.
pvonkaenel
New Contributor III
Do you ahve a solution for this problem? I have not been able to get the DX renderer to work under Vista or Win7.
Peter
dashesy
You should disable Aero, to do that choose the basic theme.
pvonkaenel
New Contributor III
Well, that did get some video in the window, but it was very slow (6 fps) - my bitblt solution is faster.
Now that we know the theme has an inpact on this, does anyone from Intel have a suggestion? I know I'm not the only one whose bumped into UMC DX render problems under Vista/Win7.
Peter
dashesy
I tracked down this problem on Win7, and it seems to be the function "UpdateOverlay" which returnes "DDERR_OUTOFCAPS". This is a known problem with Aero as discussed here. There you can find some solution, although I did not have time to try it. I am working on a OpenGl based (better say OpenSceneGraph based) video renderer so I did not dig deeper.
But I did not find the issue of slow fps! That is something I also would like to know more about
dashesy
Alexander_Modenov__I
Yes, the "DDERR_OUTOFCAPS" problem persists.
The simplest solution is to write line 538 of the dx_drv.c file as :
hRes = overlay->UpdateOverlay(&src, drv->dd_srf_primary,dst, show_cmd, 0);
if (DDERR_OUTOFCAPS == hRes) {
HDC dc;
hRes = drv->dd_srf_primary->GetDC(&dc);
dst, show_cmd, 0);
drv->dd_srf_primary->ReleaseDC(dc);
For the DX render you'll get a message about color scheme changing but everything will be the same after program ends. No messages for BLT render.
The DX and BLT renders will work fine with these changes.
I can't seen slow fps with DX and BLT
