6814 Discussions
How to run an IPP7.1 application on linux with static link command
Yuankun_Q_
How can I run an IPP7.1 application on linux with static link command? There is one example in the ipp7.1_user_guide but starting with icc (I did not install icc but only ipp). Does anyone know how to do it with gcc command? Thanks a lot for the help! (It is different from that of ipp6.1)
Gennady_F_Intel
it's not necessarily to use icc, but you can easily to use gcc compiler for that. please check the Release Notes which version of gcc compilers are supported.
Pavel_B_Intel1
The simple example:
g++ -o ipptwo ipptwo.cpp -I $IPPROOT/include $IPPROOT/lib/ia32/libippi.a $IPPROOT/lib/ia32/libipps.a $IPPROOT/lib/ia32/libippcore.a
Pavel
