6814 Discussions
I can't use simpleplayer.exe to play h.264 file.
ballofking
The IPP version is 5.3.1.064 and IPPSample version is 5.3.083. I can use simpleplayer.exe to play mpeg-4 files(.avi),but can not play h.264(.avi or .mp4).The h.264 file can play normally on vlc media player.
Vladimir_Dudnik
Hello, could you please provide problem stream? If it is not so big you can attach it here.
Vladimir
ballofking
The command message is like below.
C:Documents and SettingsKrisw_ipp-samples_p_5.3.083ipp-samplesaudio-vi
deo-codecs_binwin32_cl8>simple_player.exe 1.mp4
Audio Render : DSOUND
Thank you
ballofking
Dear Vladimir:
I have put the file above. Can you help me find out the reason.Thanks so much.
Vladimir_Dudnik
Hi, strange, I was able to play it with w_ipp-samples_p_5.3.065
Do you still have issues with that stream?
Vladimir
