IPP 3.0 & 5.0
sgajjela
Начинающий
907Просмотр.
Is there any documentation avaliable to find all the functions in IPP 3.0 are replaced by the functions IPP 5.0?
Srinivasa
0 баллов
3 Ответы
Vladimir_Dudnik
Сотрудник
907Просмотр.
Hi Srinivasa,
sure, we provide such information. Please visit IPP Technical Resources page, available from IPP main page. This page contains many useful technical information regarding IPP usage.
for your convenience, there is link for answer to you question
Intel IPP 5.0 Backward Compatibility
Vladimir
sgajjela
Начинающий
907Просмотр.
Hi Vladimir
PDFs at the above link does not list following functions (of IPP 3.0) as removed from IPP 5.0.
iplCreateImageHeader
IplAllocateImage
iplDecimate
IplThreshold
IplBlur
IplOr
IplDeallocate
IplZoom
IplSubtract
iplCreateROI
IplSetROI
IplSet
IplAlphaCompositeC
IplGrayToColor
iplYUV2RGB
iplRGB2YUV
GetLibVersion
iplClone
iplGetErrStatus
Is this means, project using IPP 3.0 would be able to build sucessfully with IPP 5.0 (because IPP 5.0 supports backwards compatability with IPP3.0)?
I look forward for your suggestion.
Thank you,
Srinivasa
Vladimir_Dudnik
Сотрудник
907Просмотр.
Srinivasa,
The PDF file I reffered you does not mention the functions from your list and there is reason for that. These functions are not Intel Integrated Performance Primitives functions. They are functions from old Intel Image Processing library, which was end of lifed at 2000.
We do support backward compatibility between different version of IPP, for example 3.0 and 5.0. The changes between 3.0 and 5.0 listed in that PDF file.
Vladimir
Ответить
