I am using ippiFFTGetSize_R_32f function from IPP 9 as below in my application
int bufferSize = 0;
int pSizeInit = 0;
int pSizeSpec = 0;
IppStatus ippStat = ippiFFTGetSize_R_32f( filterOrder(this->width) , filterOrder(this->height), IPP_FFT_DIV_INV_BY_N, ippAlgHintNone,
&pSizeSpec, &pSizeInit, &bufferSize);
Status returned is No error but pSizeInit is 0, for others(pSizeSpec,bufferSize) the values are non-zero.They have valid values.
Please let me know if usage is correct and why pSizeInit is 0.
Manoj
Hi Manoj,
would you mind following this example ?
/// get sizes for required buffers ippiFFTGetSize_R_32f( orderX, orderY, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone, &sizeSpec, &sizeInit, &sizeBuffer ); /// allocate memory for required buffers pMemSpec = (IppiFFTSpec_R_32f*) ippMalloc ( sizeSpec ); if ( sizeInit > 0 ) { pMemInit = ippMalloc ( sizeInit ); } if ( sizeBuffer > 0 ) { pMemBuffer = ippMalloc ( sizeBuffer ); } /// initialize FFT specification structure ippiFFTInit_R_32f( orderX, orderY, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone, pMemSpec, pMemInit ); /// free initialization buffer if ( sizeInit > 0 ) { ippFree( pMemInit ); } /// perform forward FFT to put source data to frequency domain ippiFFTFwd_RToPack_32f_C1R( pSrc, srcStep, pDst, dstStep, pMemSpec, pMemBuffer ); /// ... /// free buffers if ( sizeBuffer > 0 ) { ippFree( pMemBuffer ); } ippFree( pMemSpec );
Hi Manoj,
for rather small FFT orders the temporal buffer for FFT initialization is not required (static pre-calculated tables are used) - therefore there is some internal criterion for this, that depends on cpu: if(order <= MAX_ORDER_CFFT_CORE) *pSizeInit = 0;
It's normal situation for ippFFT.
regards, Igor.
Hi Manoj,
please let us know if you are experiencing any problem.
thank you.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
Topic Options
