6844 Discussions
IPP 9 ippiFFTGetSize_R_32f function fills pSizeInit as 0.
manoj_r_
I am using ippiFFTGetSize_R_32f function from IPP 9 as below in my application
int bufferSize = 0;
int pSizeInit = 0;
int pSizeSpec = 0;
IppStatus ippStat  = ippiFFTGetSize_R_32f( filterOrder(this->width) , filterOrder(this->height), IPP_FFT_DIV_INV_BY_N, ippAlgHintNone,
&pSizeSpec, &pSizeInit, &bufferSize);
Status returned is No error but pSizeInit is 0, for others(pSizeSpec,bufferSize) the values are non-zero.They have valid values.
Please let me know if usage is correct and why pSizeInit is 0.
Manoj
Jonghak_K_Intel
Hi Manoj,
 would you mind following this example ?
/// get sizes for required buffers
 ippiFFTGetSize_R_32f( orderX, orderY, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone, &sizeSpec,
&sizeInit, &sizeBuffer );
 /// allocate memory for required buffers
 pMemSpec = (IppiFFTSpec_R_32f*) ippMalloc ( sizeSpec );
 if ( sizeInit > 0 )
 pMemInit = ippMalloc ( sizeInit );
 if ( sizeBuffer > 0 )
 pMemBuffer = ippMalloc ( sizeBuffer );
 /// initialize FFT specification structure
 ippiFFTInit_R_32f( orderX, orderY, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone, pMemSpec, pMemInit );
 /// free initialization buffer
 if ( sizeInit > 0 )
 ippFree( pMemInit );
 /// perform forward FFT to put source data to frequency domain
 ippiFFTFwd_RToPack_32f_C1R( pSrc, srcStep, pDst, dstStep, pMemSpec, pMemBuffer );
 /// free buffers
 ippFree( pMemBuffer );
 ippFree( pMemSpec );
Igor_A_Intel
Hi Manoj,
for rather small FFT orders the temporal buffer for FFT initialization is not required (static pre-calculated tables are used) - therefore there is some internal criterion for this, that depends on cpu: if(order <= MAX_ORDER_CFFT_CORE) *pSizeInit = 0;
It's normal situation for ippFFT.
regards, Igor.
Jonghak_K_Intel
Hi Manoj,
please let us know if you are experiencing any problem.
thank you.
