IPP FFT application on AMD
Julian_S_
I am working on an application that uses the FFT of IPP.
It needs to run on Intel as well as on AMD processors.
I am not asking for an optimized performance. I am simply interested whether my "ready to deploy" application will run on either systems.
I browsed the forum a little, but could not find a suitable answer.
Thank you in advance
Best regards
Julian
Thomas_Jensen1
I'm using IPP in a project, and I also require AMD support. Since I see sufficient performance in my application using CPU level "SSE2", I primarily use that when initializing IPP. There is no current CPU that does not support SSE2 as far as I know.
I have compiled a custom interface to a small foot-print IPP, I only have 12MB DLL size, still using many functions and multi threading.
Thomas
Shaojuan_Z_Intel
Intel IPP library supports Intel and compatible architectures. IPP function doesn't differentiate CPUs by vendor - Intel or non-Intel. It differentiates them by supported instruction sets, such as AVX512, AVX2, SSE4.2, etc.
