fftshift
siddy
Hi all,
     Again, trying to transcode some matlab ideas to IPP based C++ : is there a similar function in IPP that
performs the fftshift operation, as in Matlab? (shift zero frequence to the center of the space). Or, if someone can confirm that the FFTFwd etc.
already result in transforms in this format, and that fftshift operation is not required.
Sid.
Chuck_De_Sylva
Can you submit a sample of what you are trying to do in Matlab code? Thanks.
siddy
F = fftshift(fft2(I)) where I is MxN image. Q: is fftshift needed for IPP fft, and if yes, how to do it? Sid.
John_M_1
Ever got an answer to your question, siddy?
Chao_Y_Intel
When I check the fftshift function here:  http://www.mathworks.com/help/matlab/ref/fftshift.html
For vectors, fftshift(X) swaps the left and right halves of X. For matrices, fftshift(X) swaps the first quadrant with the third and the second quadrant with the fourth.
Could you try to use the ippiCopy_xxx function to swaps these data one by one block?
Chao
Royi
@Chao,
It would be great to have something like that out of the box.
Mainly that it is crucial when visualizing the Spectrum.
Thank You.
