IppsFIR and Initial Conditions
Jay_Schamus
I'm trying to use IppsFIR() to get the same results as the MatLab function filter(). For example, if I do the following call in ML:
y = filter( b, 1, x );
and then use the IPP functions():
IppsFIRState_64f *pState;
ippsFIRInitAlloc( &pState, *b, lenb, NULL );
ippsFIR( *x, *y, lenx, pState );
I get the same results in ML and IPP.
But if I do the following in MatLab:
y = filter( b, 1, x, zi );
and the following in IPP:
ippsFIRInitAlloc( &pState, *b, lenb, *zi );
The results are not at all the same. The ML results are ~ the same as point-by-point adding zi to the length zi number of points at the beginning of y. As for the IPP results, I don't have a clue as to what it's doing. The zi I'm using is symmetric, so it's not a matter of flipping it left-right, but obviously I'm missing something. The zi I'm using is symmetric, so it's not a matter of flipping it left-right, but obviously I'm missing something.
Any ideas on how to get IPP to work like MatLab without simpling adding the intitial conditions to the output?
igorastakhov
New Contributor II
"filter" in Matlab corresponds to IIR filter - when you use "null" delay line and a[0]=1 - it works as FIR, but when you use initialized delay line - "filter" considers it as IIR direct form 2 delay line (see description for "filter" in the manual); IPP FIR considers delay line as simple tapsLen-1 delayed source. For full correspondence with "filter" you should use IPP IIR functionality and recalculate zi (delay line) to direct form 2 as it's described in Matlab documentation (ippsIIR also uses direct form 2 delay line). Or if you need only FIR - you should use your direct form1 delay line for IPP and for Matlab you should recalculate it to the direct form2:
for( i = 0; i < order; i++ ){
pDly = 0;
for( n = order - i; n > 0; n-- ){
pDly += pTaps[n+i] * pSrc[len-n]; /* b- corfficients */
pDly -= pTaps[order+n+i] * pDst[len-n]; /* a- coefficients */
Igor
Jay_Schamus
Doh!
Thanks, Igor. I didn't make the connection that of course ML is always using an IIR filter even when the denominator coefficients are just 1. Been too long since I took my filters classes.
Thanks again.
