Is there something wrong with MPEG4 in ipp5.0?
walkdeath
I've tried to encode a video file using the sample application "video_enc_con".
First time I use mpeg4 encoder, but when I use "simple player" to play it, it said that "Failed to initialize splitter".
But second time I used the h264 encoder, it could be successfully played by the "simple player".
And another problem comes when I changed the sample in the umc_manul to mped4-decoder, I could only get an empty file just as Scott said.
Vladimir_Dudnik
we found solution for Scott's issue andwere not able to reproduce issue withMPEG4 encoder and simple_player. Could you please provide more details about that? Did you change encoder parameters?
Vladimir
walkdeath
Hi Vladimir,
Nowadays I'm writint the mpeg4 decoder using your code for scott as sample. But when I run it in fedora core 4, there is always a "segment fault".
So I looking into the GetFrame function in mpeg4decoder class. I found that there is always no data in "out"(MediaData* out). Is that right? I think there should be something in "out", so that videorender can process it. I print the length of out, it's always 0. But the simple player could always running alright. So I'm really confused...
When I looking into the problem "segment fault", I found that it appeared at " umcRes = dst.RenderFrame();" So I found the function RenderFrame() in FWVideoRender class and found that problem was in
for (int i = 0; i < m_SrcInfo.height; i++)
umcRes = m_pFileWriter->PutData((unsigned char *)m_Buffers[m_iReadIndex].surface + i * m_nPitch, nbytes);
if (UMC_OK != umcRes)
break;
So please help me about this question. Any suggestion would be great appreciated~~~
Wu Yu
Vladimir_Dudnik
Hi Yu,
if you can attach a sample data it can simplify investigation of the issue.
Vladimir
