6825 Discussions
compress / decompress grayscale images with 8 or more bits per pixel
florin_seceleanu
I would like to know if I can use the IPP library to compress/decompress grayscale images with 8 or more bits per pixel to/from lossless JPEG . I think that older versions were limited to 8 bits.
Thank you,
F.
Vladimir_Dudnik
JPEG codec in JPEGView sample supports lossless mode for 2..16 bit images. The limitation is that only 1 channel images are supported right now. Please let us know if you are interested in support formore channels
Vladimir
florin_seceleanu
Thank you for your prompt answer.
1. Ok, so I understand that it does support images with only one channel that have 8, 10, 12 or 16 bit per channel. Am I correct?
2. How about JPEG2000, does it have the same support? I am very interested in that, too.
3. I wonder if there is any sample code that decompresses a grayscale image from JPEG, respectively from JPEG2000.
Thanks again,
F.
Vladimir_Dudnik
Hi, I'm sorry for delay,
1. Yes, absolutely. You can look at JPEGView sample for more details. Actually it automatically scale output data to 8-bit range for display purpose, but you can change that.
2. Yes, again. Our JPEG2000 sample do support images with up to 32-bit per color component, see our JPEG2000 sample.
3.Yes, just download IPP JPEG samples
Vladimir
