Java JNI Can't find dependent libraries
Samuel_L_1
I want to call ipp function via JNI. So I compiled dlls using c++ and I put these dlls into my Java project lib folder.
but when I call one ipp function jipp.core.ippGetCpuType(), it gives me error like:
Exception in thread "main" java.lang.UnsatisfiedLinkError: D:\DevelopJava\MyIPP\lib\jippcore.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(Unknown Source)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at jipp.core.<clinit>(core.java:42)
at client.zero.main(zero.java:16)
but I already set java.library.path include intel path like:
\Program Files (x86)\Intel\Composer XE 2013\redist\intel64\ipp
D:\Program Files (x86)\Intel\Composer XE 2013\redist\intel64\compiler
so ,anyone can help me ?
Chuck_De_Sylva
Samuel,
Do you know which libraries you are linking too? That is, single-threaded or multi-threaded?
- Chuck
Samuel_L_1
java->jipp.core.ippGetCpuType()->JNI->ippcore-7.1.dll
Samuel_L_1
sorry.  I restart the compute and test again. it's working. oh, eclipse is very bad.
SergeyKostrov
Valued Contributor II
>>...when I call one ipp function jipp.core.ippGetCpuType(), it gives me error like: >> >>Exception in thread "main" java.lang.UnsatisfiedLinkError: D:\DevelopJava\MyIPP\lib\jippcore.dll: Can't find dependent libraries Samuel, I will do a verification in my very simple JNI+IPP test project with a call to ippGetCpuType IPP function. Let you know results as soon as it is completed.
