Java interface in 5.0?
pascal_bamford
Before downloading 5.0b, there was a question asking whether I was going to evaluate the'Java interface to all IPP entries'.
Did this feature not make it into the beta version?
Thanks for all your great work -I have been usingand relying onIPP since 1.0b.
- Pascal.
Ying_S_Intel
Pascal,
Thanks for your comments.
Yes we do have Java interface implementation offered in IPP 5.0 beta, they are introduced as sample. You can find IPP samples with Java interface for both Windows* and Linux* in "Beta Intel IPP Samples" product via Intel Premier Support. Please download and evaluate these java samples. Let us know how you think these new samples.
By the way, this posting contains all IPP 5.0beta sample descriptions:
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=2380
Hope it helps.
Ying
pascal_bamford
Are the .h files missing from ipp_sample->java->src->native?
Vladimir_Dudnik
headers are generated automatically, by javah
Vladimir
Samuel_L_1
   I have native c file and I generated header file, but when i compile them using Visual C++, it give me errors.
SergeyKostrov
Valued Contributor II
>>... I have native c file and I generated header file, but when i compile them using Visual C++, it give me errors. Samuel, Could you post a complete compilation output with these errors? Also, what version of Microsoft compiler ( IDE ) do you use?
Samuel_L_1
another question is I want to replace String class in Java to enhance the performace like ippstring in C# ( it gives me 100 times performance enhancement), but i C#, we can use
fixed( char* ps=str, pd=this.value )
sp.ippsCopy_16s( (short*)ps, (short*)pd, str.Length );
but we cannot use pointer in Java, so the question is how to call sp.ippsCopy_16s in Java?
big thanks
Bernard
Is there a possibility to use JNI? In Java are passed reference of type String which internally behaves as a pointer.How to implement it in your code I do not know.
SergeyKostrov
>>...so the question is how to call sp.ippsCopy_16s in Java? I think the best way is C-wrappers around all IPP functions you want to use and these C-wrappers need to be called using JNI. There are lots of examples on the web on how to do it ( I mean how to call a C function in a DLL from Java ). I could send you a very small project that demonstrates application of JNI. In overall, a Java applet calls a function in a DLL implemented in C language.
Samuel_L_1
actually i want to write a new class to replace java.lang.String. But we know in java string we use char[] to store data of string., like
public final class String implements java.io.Serializable, Comparable<String>,CharSequence {
/** The value is used for character storage. */
private final char value[];
/** The offset is the first index of the storage that is used. */
private final int offset;
/** The count is the number of characters in the String. */
private final int count;
when i want to call the function like sp.ippsCopy_16s or sp.ippsCopy_16sc, I didn't find any function support char[] parameter, actually
in JNI is :
     public static native int ippsCopy_16s ( short pSrc[], short pDst[], int len)
so the question is how can I use IPP functions in Java for char type? ( Shall I use short type?)
SergeyKostrov
>>...so the question is how can I use IPP functions in Java for char type? ( Shall I use short type?) You need to look at JNI ( Java Native Interface ) and it is an additional layer between a Java application, or applet, and functions implemented in a C/C++ DLL(s).
