Legacy IPP headers do not compile with 2018 Update 3 in Visual Studio
Anton_Sonushkin
ビギナー
2,289件の閲覧回数
Compilation c++ code with IPP legacy headers gives  the following errors after updating to Parallel Studio XE 2018 Update 3.
An example code could contain just:
#include <ippi90legacy.h>
Severity    Code    Description    Project    File    Line    Suppression State
Error    C2146    syntax error: missing ';' before identifier 'legacy90ippiInit'    ipp_legacy_err    c:\program files (x86)\intelswtools\compilers_and_libraries_2018.3.210\windows\ipp\include\ippi90legacy.h    58
Error    C4430    missing type specifier - int assumed. Note: C++ does not support default-int    ipp_legacy_err    c:\program files (x86)\intelswtools\compilers_and_libraries_2018.3.210\windows\ipp\include\ippi90legacy.h    58
Error    C2086    'IppStatus __STDCALL': redefinition    ipp_legacy_err    c:\program files (x86)\intelswtools\compilers_and_libraries_2018.3.210\windows\ipp\include\ippi90legacy.h    74
0 件の賞賛
6 返答(返信)
Chao_Y_Intel
モデレーター
2,289件の閲覧回数
Thanks for the report, and we are checking this code.
regards,
Chao
Gennadiy_L_
ビギナー
2,289件の閲覧回数
Hi. After last Visual Studio 2017 update IPP installing vithout integration vith VS.
Gennadiy L.
HUR__CENGIZ
ビギナー
2,289件の閲覧回数
I am trying to run an empty hello world code (IPP 2018), but it does not compile on VS 2017 or QT Creator.
Code is as follows:
#include "ipps90legacy.h"
Del::Del()
    ippInit(); // Initialize Intel IPP dispatcher
Come up with 152 errors saying things like:
syntax error: missing ';' before identifier 'legacy90ippsInit'
Is there any way to run legacy libs with IPP 2018, MSVC 2017 64bit? Or any alternative to compile old code written with earlier versions ( <= IPP 8) with IPP 2018 ? Or where can I find earlier versions of IPP?
Thanks, regards
Cengiz
HUR__CENGIZ
ビギナー
2,289件の閲覧回数
Code is as follows:
Del::Del()
Thanks, regards
Cengiz
Pavel_B_Intel1
従業員
2,289件の閲覧回数
Hi Gengiz,
I'm sorry to ignore your question so long time. Yes we changed IPP header files in IPP 2018 release to be compliant with C language standard. This is a simple workaround:
add only 3 lines of code:
#if !defined( __STDCALL )
#define __STDCALL IPP_STDCALL
#endif
these lines can be added either before any "legacy" header declaration, or embedded into ippdefs90legacy.h after line #35:
#ifndef __IPPDEFS_90_LEGACY_H__
#define __IPPDEFS_90_LEGACY_H__
#include "ippbase.h"
#include "ipptypes.h"
#endif
Pavel
mcolina1
ビギナー
2,289件の閲覧回数
Pavel Berdnikov (Intel) wrote:
Hi Gengiz,
#endif
#endif
Pavel
Confirmed this works. Thanks.
-Mike
返信
