Linux Arch
reportbase
IPP does not install on linux arch distributions. Arch is the hot new linux distro and needs to be supported. Please provide instructions about how we can install it on arch, even if its a hacky way. Please add Arch to your linux distros that you support. Should just be a matter of modyfing install scripts.
PaulF_IntelCorp
You might have to force the rpm files to install or use something like rpm2cpio to install the files. You'll also have to update the ippvars.sh files to point to the IPP install directory (default is /opt/intel/...) if you want to use those scripts to setup your build environment. Using the ippvars.sh to setup your build environment is optional. See this forum message for some possible help:
http://software.intel.com/en-us/forums/showthread.php?t=77591
