6847 Discussions
how to replace zero values in an image with another arbitrary value
Kadir_Kirtac
Hello, I want to replace zero values in a 32f image with another floating point value. I tried to combineippiCompareC with ippiThreshold function but couldn't succeed. Is there any simple solution for this purpose?
Ying_H_Intel
Hi Kadir,
Could you clarify theexact problem when combine the ippiCompareC and ippiThreshold.
It was expected the functions like ippiThreshold_Val can set the pixel which meet some condition ( value=0.0f)to other floating point value.
IppStatus ippiThreshold_Val_(const Ipp* pSrc, int srcStep,
Ipp* pDst, int dstStep, IppiSize roiSize, Ipp threshold,
Ipp value, IppCmpOp ippCmpOp);
but could bebecause that zero values in floating point value is hard to defined?
YingH.
Kadir_Kirtac
Sorry I have completely missed outippiThreshold_Val. I was just trying to use Threshold_LTVal, Threshold_GTValetc..
That will exactly solve the problem.
Best regards.
