C# VS2010 Win7 32bit simple ipp example
khalberg
I have added the following statement to my WPF VS2010 Win7 32bit C# application:
String cpuType = "Cpu Type=" + core.ippGetCpuType());
I can not get it to find the ippcore-7.0.dll file. Error is "Unable to load DLL 'ippcore-7.0.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)".
I have added this to the environmental variables and have tried adding references to the dll (error adding reference as well). I have also copied the ia32/lib files to Windows\\System32 and to my bin/debug directory.
What is preventing the application from finding the file?
Kevin
Naveen_G_Intel
Hi Kevin,
This error message is because of IPP path setting problem, I noticed many times. Please make sure you are added right PATH name in the VS 2010 properties. Specifically include and lib.
Naveen Gv
khalberg
Can you be a little more specific please. I have "C:\Program Files\Intel\ComposerXE-2011\redist\ia32\ipp;" as the first entry in the Path for system variables. I have ippcore.cs in my local build directory and a reference to ippdefs_cs.dll.
khalberg
I was able to get things working by running the compile_vars.bat file as administrator and launching VS 2010 from there. PATH was not sufficient to make this work. Kevin
