I believe it can be made exteremly efficient much more than the current greater/less functions.
Adi
Hi Adi,
the question is does IPP optimized code uses special CPU instructions? The answer is - yes, of course. We always try to use CPU hw capabilities if they can help us to reach better performance.
Vladimir
Actually, this wasn't really my question. Since as you say you use special CPU instruction, it seems starnge that there isn't one atomic operation for getting the min(max) of 2 images(arrays).
The current implementation requires keeping an intermidiate result mask e.g for later assignment. Though convenient for some things, other operation can benefit from avoiding this second image pass.
Adi
So, you talk about something like this:
ippiMin_8u_C1R(pSrc1,pSrc2,pDst),
where pDst[i[]
Is that right?
Vladimir
Sure. Will do.
Adi
By the way, have you seen ippsMinEvery/ippsMaxEvery API in ippSP library? Wesupport 16s/32s/32f data types for in-place operations, so you can use them for images at row-by-row basis.
Vladimir
Hmm.. I haven't seen this. You're right, I can use this for depths larger than 8-bit.
This is what I wanted for images too.
Adi
Ok, I'm gladthat this info was useful somehow:)
Please do not forget to submit request for new functionality through the premier support service. Of course, it does not mean we automatically accept it, but we will consider it for the next versions of IPP. You understand, it always some compromise between what we want to do and what we can, at least at this moment:)
Thank you,
Vladimir
Already submitted :-)
Adi
Well, five years laster it seems that the requested function is still unavilable.
Have you noticed bellow function :
ippiMinEvery_
It suport 8u, 16u, 16s, 32f type. Is this what your required?
Chao
ippiMinEvery_
Chao
I am terribly sorry.
I assumed that that MinEvery_ should belongs to either arithmetic, filtering or comparing operations without looking through the manual.
Thank your for your quick response.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
