Modified MP4 splitter sample
Tamer_Assad
创新者
1,381 次查看
This thread discusses Chaos sample splitter, and presents a modified version using also Chaos sample decoder.
The modified version doesnt use fwRender, yet, it still outputs a YUV file.
Many thanks to Chao for providing such helpful examples.
Code file attached: modifiedSplitter.cpp
This is an extension to thread:
http://software.intel.com/en-us/forums/showthread.php?t=79645&o=a&s=lr
Tamer Assad
0 项奖励
7 回复数
Ying_H_Intel
主持人
1,381 次查看
HiTamer,
Thank you a lot for the sharing. Right, I agree you that
If this is the case, you do not need any rendering process, all you need is to decode your frames and use your existing calls to out.GetPlanePointer or call out.GetBufferPointer() once per frame;
The decoder outputs YUV frames already!
I guessUlisses87 may worry about thecYUVData buffer is overflowing
when keeprun thedecoder wherecYUVData willkeep increase.
status = videoDecoder->GetFrame(&in,&out);
//// imported code
if(status == UMC::UMC_OK)
cYUVData += frameSize;
out.SetBufferPointer(cYUVData,frameSize);
frameNumber++;
Actually, the buffer can be overwrited. (you don't need move the pointer)
for example,
umcSts = out.Init((Ipp32s) videoInfo->clip_info.width, (Ipp32s) videoInfo->clip_info.height, UMC::ColorFormat::YUV420, 8);//, Ipp32s iBitDepth = 0);
umcSts = out.Alloc();
ret =videoDecoder-> GetFrame((NoFramesForDecoder) ? (NULL) : &in, &out);
if (ret != UMC::UMC_ERR_NOT_ENOUGH_DATA && ret != UMC::UMC_OK)
return false; // error
if (ret == UMC::UMC_OK)
numDecFrames++;
printf(" decoder frame %d \n", numDecFrames);
// if you'd like to see the frame,you can store frame
WriteFrame(outDecoderfp, out, imgWidth, imgHeight);
Here is one stream (or pipeline)encoder/splitter/decoder sample code
No sureif i had attachedit somewhere,attached it again.it is for VC1codec, but the loop and processing is same for H.264 or MP4.
Seems wemay add the streaming sample to the get start sample.
Ying
0 项奖励
ulisses87
初学者
1,381 次查看
Hi, again,
Many thanks Ying Hfor such useful example of code. Now, my code is working (almost) perfectly, what's mean that it does not save output yuv file :). I simply throw away fwRender object and added out.Init() and out.Alloc() referneces. Off course I have to change other parts of code. I'm really happy :).
0 项奖励
Chao_Y_Intel
主持人
1,381 次查看
Thanks all of you, for sharing the code. It is very useful for users to learn the comprehensive UMC sample code here..
Chao
0 项奖励
ulisses87
初学者
1,381 次查看
Welcome you warmly!
I am just after my Engineer diploma defence.
I would like to express my thanks to all people from Intel Team, which helped me via this forum when I was doing my Engineer Degree final project. Your valuable advices and tips often were an important "signpost", which enabled me to get the proper way to solve my problems.
I have a small problem. Recently Intel has awarded me with Brown Belt of Intel Software Network, so I received an e-mail with info, that I can choose an one free book from Intel Press. Despite, that I have provided every necessary information, from one month I haven't had any reply. Could you advise me, what I should to do at this matter?
0 项奖励
Chao_Y_Intel
主持人
1,381 次查看
This is a FAQ I can find on the brown belt:
http://software.intel.com/en-us/articles/intel-brown-belt-software-developer-and-intel-green-belt-software-developer-faqs/?wapkw=ALL(brown+belt)
This may provide some help on your problem.
Chao
0 项奖励
ulisses87
初学者
1,381 次查看
Hello Chao,
Thank you again for your help. The book was delivered at me today.
Ulisses87
0 项奖励
99sanni
初学者
1,381 次查看
VirtualDub,Wax, Avidemux,Avid FreeDV, Wax all are free video editor, and
I just split mp4 files into one with the MP4 splitter for mac
0 项奖励
回复
