I`ve compare the SM3/4 performance of the ippcp and openssl. Here is the test result :
sm3: sm4:
64 1024 65536 64 1024 65536
ippcp2019_with_dynamic_lib 1628664 208877 3528 TPS 113385 7141 111 TPS
ippcp2019_with_static_lib 1619249 212247 3530 TPS 504006 35565 562 TPS
openssl_1.1.1 1084010 141426 2300 TPS 371751 38036 621 TPS
I think the IPP Crypto could do much better than OpenSSL, but I only got this. I hope someone could help me with this. I paste my test code of SM3/4 with IPP Crypto below(l_ippcp_2019.0.117):
gcc -O3 ippcp_SM4_CBC_test.c -o ippcp_SM4_CBC_test -I/opt/intel/compilers_and_libraries_2019.0.117/linux/ipp/include -I/opt/intel/compilers_and_libraries_2019.0.117/linux/ippcp/include /opt/intel/compilers_and_libraries_2019.0.117/linux/ippcp/lib/intel64_lin/libippcp.a
#include "ipp.h"
#include "ippcp.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int SM3_ContextSize = 0;
int main(int argc, char *argv[])
char mess0[65536] = { 0 };
unsigned char mres[64] = { 0 };
int byte, i;
float time_use = 0;
struct timeval start;
struct timeval end;
long my_tps = 0;
long repeattime = 0;
if (argc != 3)
printf("Usage: %s byte(s) repeattime\n", argv[0]);
printf("byte(s) only can be like :64 1024 65536\n");
exit(1);
byte = atoi(argv[1]);
repeattime = atol(argv[2]);
ippsSM3GetSize(&SM3_ContextSize);
gettimeofday(&start, NULL);
IppsSM3State *sm3_context = (IppsSM3State*)malloc(SM3_ContextSize);
for (i = 0; i < repeattime; i++)
memset(mess0, 49, byte);
ippsSM3Init(sm3_context);
ippsSM3Update((unsigned char*)mess0, byte, sm3_context);
ippsSM3Final(mres, sm3_context);
/*int j;
for (j = 0; j < 32; j++)
printf("%02x", mres);
printf("\n");*/
memset(mres, 0, 64);
gettimeofday(&end, NULL);
time_use = (end.tv_sec - start.tv_sec) * 1000000 + (end.tv_usec - start.tv_usec);
printf("time_use is %f\n", time_use);
my_tps = repeattime * 1000000L / time_use;
printf("TPS: %ld\n", my_tps);
free(sm3_context);
return 0;
gcc -O3 ippcp_SM3_test.c -o ippcp_SM3_test -I/opt/intel/compilers_and_libraries_2019.0.117/linux/ipp/include -I/opt/intel/compilers_and_libraries_2019.0.117/linux/ippcp/include /opt/intel/compilers_and_libraries_2019.0.117/linux/ippcp/lib/intel64_lin/libippcp.a
#include "ipp.h"
#include "ippcp.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int SM4_CBC_ContextSize = 0;
int main(int argc, char* argv[])
IppStatus istate;
unsigned char pkey[16] = {
0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef,
0xfe, 0xdc, 0xba, 0x98, 0x76, 0x54, 0x32, 0x10,
unsigned char pIV[16] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
int keyLen = 16;
Ipp8u* pKey = pkey;
int byte, i;
float time_use = 0;
struct timeval end;
char a[65536] = { 0 };
long my_tps = 0;
if (argc != 3)
exit(1);
ippsSMS4GetSize(&SM4_CBC_ContextSize);
memset(a, 49, byte);
IppsSMS4Spec* sm4_cbc_context = (IppsSMS4Spec*)malloc(SM4_CBC_ContextSize);
IppsSMS4Spec* sm4_cbc_context2 = (IppsSMS4Spec*)malloc(SM4_CBC_ContextSize);
istate = ippsSMS4Init(pKey, keyLen, sm4_cbc_context, SM4_CBC_ContextSize);
istate = ippsSMS4Init(pKey, keyLen, sm4_cbc_context2, SM4_CBC_ContextSize);
ippsSMS4SetKey(pKey, 16, sm4_cbc_context);
ippsSMS4SetKey(pKey, 16, sm4_cbc_context2);
//encryption
//istate = ippsSMS4Init(pKey, keyLen, sm4_cbc_context, SM4_CBC_ContextSize);
unsigned char b[65536];
//ippsSMS4SetKey(pKey, 16, sm4_cbc_context);
istate = ippsSMS4EncryptCBC((unsigned char*)a, b, byte, sm4_cbc_context, pIV);
if(ippStsNoErr != istate)
printf("ippsSMS4EncryptCBC err %d\n", istate);
break;
/*for (j = 0; j < byte; j++) {
printf("%02x ", b);
printf("\n");*/
/*gettimeofday(&end, NULL);
printf("time_use is %f\n", time_use);*/
//decryption
unsigned char c[65536];
//istate = ippsSMS4Init(pKey, keyLen, sm4_cbc_context2, SM4_CBC_ContextSize);
//ippsSMS4SetKey(pKey, 16, sm4_cbc_context2);
istate = ippsSMS4DecryptCBC(b, c, byte, sm4_cbc_context2, pIV);
printf("ippsSMS4DecryptCBC err %d\n", istate);
break;
printf("%c", c);
printf("\n");*/
free(sm4_cbc_context);
free(sm4_cbc_context2);
return 0;
Hi, Xuexu,
Thanks for test code. We need to reproduce your issue here.
could you submit the test code into our support ticket. Here are some steps you can follow:
https://software.intel.com/sites/default/files/managed/d5/ce/SubmittingSupportIssue.pdf
Our support export will check this code.
regards,
Chao
it would be also very useful if you will provide 1/ the CPU type you are running this application and 2/ and don't measure the initialization part of this computations like ippsSMS4Init .
Gennady F. (Intel) (Blackbelt) wrote:it would be also very useful if you will provide 1/ the CPU type you are running this application and 2/ and don't measure the initialization part of this computations like ippsSMS4Init .
1) I run my test code on virtual machine of alibaba cloud. The CPU is Intel(R) Xeon(R) CPU E5-2682 v4 @ 2.50GHz, kernel for a single CPU.
2) I did not measure the initialization part of this computations like ippsSMS4Init, you can cheak the code above, it has been commented out.
Thank you!
Zhu Xuewu
Chao Y (Intel) (Intel) wrote:Hi, Xuexu,
https://software.intel.com/sites/default/files/managed/d5/ce/SubmittingS...Our support export will check this code.
regards,
Chao
Hi, Chao,
I have submit the test code and some information about my test environment. I am looking forward to receiving your reply.
Zhu Xuewu
Xuexu, we assigned owner to this ticket and we will try to reproduce this case on our side.
Hi, Xuewu,
We further investigate the code performance:
The SM4-CBC-DEC operation in IPP much faster, but the SM4-CBC-ENC is a bit slower. The performance difference is because BC-ENC has dependency in the input data, but CBC-DEC has no. In IPP SM4 BC-ENC part, it chooses some more secure way for implementation, which has the performance cost.
Chao
