Problem using ippi.5.1.dll
gabrielcuba
I amusing the ippi-5.1.dllfromc# code in Visual Studio 2005 and works fine. When i move the resulting application and the ipp dll to another machine and try to run it i getthe followingerror:
Unable to load DLL 'ippi-5.1.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
What did i miss?I have to copy more dlls?
I will appreciate any collaborations!
Vladimir_Dudnik
can you ensure your application actually able to find the DLL? Is it accessible through PATH variable or is it resides in the same folder where the executable is? Does your target system contain new CRT, provided in VS2005?
Vladimir
