Problems with ResamplePolyphase
Lutz_A_
hello,
can you help me, by giving me an example to the usage of the function : ippsResamplePolyphase_32f. The manual makes me confusing :-)
please, can anyone give me an very easy example which resamples an float array with an arbitrary factor ..
thanx , and sorry for the bad english :-)
Lutz Altmann
Intel_C_Intel
Hi, Lutz,
There is resampling example in IPP examples (IPPSR/Speech_Processing/Resampling) thatresamples a pcm file.
It contains resampling with a rational factor (by ResamplePolyphaseFixed function), with an arbitrary factor (by ResamplePolyphase function), using float foint and integer calculations
Alexander
klend
akibkal1 wrote:
Hi, Lutz,
There is resampling example in IPP examples (IPPSR/Speech_Processing/Resampling) that resamples a pcm file.
Alexander
Could it be that that code is not in everyone's package? I seem to have only the samples media and speech-coding (on ia32, version 5.0), but I would like to have a look at the resampling examples too. Is it possible to get those as well?
Thanks in advance.
