Finiding the coefficients of a transform matrix
giora1
I am currentlly using the ippi library for computer vision.
I perform geometric transforms using the following functions:
ippiWarpBilinearQuad
ippiWarpAffineQuad
Does anyone know of a way to get the coefficients ofthe matrixs used in thesetransformations?
Thanks in advance,
Giora
Intel_C_Intel
Hi, Giora,
It could be done by ippiGetAffine/BilinearTransform function if your argument quadrangle is a rectangle. In other case some matrix manipulation are necessary
Eg for affine transform you could form and solve the system of 6 linear equations for 3 of quadrangle corners. Pixel indices are coordinates:
x0'=c00*x0+c01*y0+c02
y0'=c10*x0+c11*y0+c12 etc
Alexander
giora1
Dear Alexander,
Thanks for your answer. Unfortunately my argumant is not rectangular.
Do you know what functions in IPP can help me to solve the system of 6 linear equations?
Thanks again,
Giora
Vladimir_Dudnik
there is OpenCV sample for general case
Code:
/* Calculates coefficients of perspective transformation
 * which maps (xi,yi) to (ui,vi), (i=1,2,3,4):
 *      c00*xi + c01*yi + c02
 * ui = ---------------------
 *      c20*xi + c21*yi + c22
 *      c10*xi + c11*yi + c12
 * vi = ---------------------
 * Coefficients are calculated by solving linear system:
 * / x0 y0  1  0  0  0 -x0*u0 -y0*u0  /c00 /u0
 * | x1 y1  1  0  0  0 -x1*u1 -y1*u1 | |c01| |u1|
 * | x2 y2  1  0  0  0 -x2*u2 -y2*u2 | |c02| |u2|
 * | x3 y3  1  0  0  0 -x3*u3 -y3*u3 |.|c10|=|u3|,
 * |  0  0  0 x0 y0  1 -x0*v0 -y0*v0 | |c11| |v0|
 * |  0  0  0 x1 y1  1 -x1*v1 -y1*v1 | |c12| |v1|
 * |  0  0  0 x2 y2  1 -x2*v2 -y2*v2 | |c20| |v2|
 *   0  0  0 x3 y3  1 -x3*v3 -y3*v3 / c21/ v3/
 * where:
 *   cij - matrix coefficients, c22 = 1
CV_IMPL CvMat*
cvWarpPerspectiveQMatrix( const CvPoint2D32f* src,
                          const CvPoint2D32f* dst,
                          CvMat* matrix )
    CV_FUNCNAME( "cvGetPerspectiveTransformMatrix" );
    __BEGIN__;
    double a[8][8];
    double b[8], x[9];
    CvMat A = cvMat( 8, 8, CV_64FC1, a );
    CvMat B = cvMat( 8, 1, CV_64FC1, b );
    CvMat X = cvMat( 8, 1, CV_64FC1, x );
    int i;
    if( !src || !dst || !matrix )
        CV_ERROR( CV_StsNullPtr, "" );
    for( i = 0; i < 4; ++i )
        a[0] = a[i+4][3] = src.x;
        a[1] = a[i+4][4] = src.y;
        a[2] = a[i+4][5] = 1;
        a[3] = a[4] = a[5] =
        a[i+4][0] = a[i+4][1] = a[i+4][2] = 0;
        a[6] = -src.x*dst.x;
        a[7] = -src.y*dst.x;
        a[i+4][6] = -src.x*dst.y;
        a[i+4][7] = -src.y*dst.y;
        b = dst.x;
        b[i+4] = dst.y;
    cvSolve( &A, &B, &X, CV_SVD );
    x[8] = 1;
    X = cvMat( 3, 3, CV_64FC1, x );
    cvConvert( &X, matrix );
    __END__;
    return matrix;
Vladimir
giora1
Hi Vladimir,
Thanks for your detailed answer - this might do the work for me.
Giora
