Rotate/Resize using more thread IPP 2017
Roni_F_
Using ippiWarpAffineLinear_8u_C3R  , ippiResizeNearest_8u_C3R
will it use one thread , or it's possible to set it to use more threads ?
Ying_H_Intel
Hi Ronifl,
What IPP version are you using?  There are some ways to using more threads
1) you can create your own external threading on the function. The external threading is recommended, which is more  effective than the internal threading.
for example,
https://software.intel.com/en-us/articles/threading-IPP-resize-with-TBB
2) using IPP internal threading,
Please see more in the article.
https://software.intel.com/en-us/articles/intel-integrated-performance-primitives-intel-ipp-threading-openmp-faq
Ying
Threading in Intel IPP 8.1 and earlier versions
Threading within the deprecated multi-threaded add-on packages of the Intel IPP library is accomplished by use of the OpenMP* library. Intel IPP 8.0 continues the process of deprecating threading inside Intel IPP functions that was started in version 7.1. Though not installed by default, the threaded libraries can be installed so code written with these libraries will still work as before. However, moving to external threading is recommended.
Valentin_K_Intel
Hi Ronifl,
The functions  ippiWarpAffineLinear_8u_C3R and ippiResizeNearest_8u_C3R do not support internal threading.
However these functions can be used for image processing by tiles with external threading.
Resizing a Tiled Image with One Prior Initialization: https://software.intel.com/en-us/node/504353#TILING_IMAGE_WITH_ONE_INIT
Warping a Tiled Image with One Prior Initialization: https://software.intel.com/en-us/node/529049#TILED_IMAGE_WITH_ONE_INIT
Valentin
