6845 Discussions
Specifying 'Fill Values' for ippiWarpAffineLinear function in IPP9
Anchit_D_
I am using the ippiWarpAffineLinear function to apply a transform to my image.
Is there a way to specify 'Fill Values' in the output image? By Fill Values I am referring to the pixels in the destination image which are mapped from pixels outside the source image.
Thanks in advance.
-Anchit
Valentin_K_Intel
Hi Anchit,
To specify 'Fill Values' in the output image, you should set the borderType parameter as ippBorderConst and set the pBorderValue parameter when initializing the IppiWarpSpec structure by the function ippiWarpAffineLinearInit. Then the pixels in the destination image which are mapped from pixels outside the source image are set to the constant value specified in pBorderValue. The data type of pBorderValue is automatically converted from Ipp64f to the data type of the processed images.
Valentin
