Super Sampling with square pixels?
paullumidium_com
Hi
I am revisiting an old project written with ippi 4.
I want to reduce large images using SuperSample. I also want to keep the scaling in both directions identical. I think I want to use.
ResizeSqrPixel
In the docs there is an interpolation mode called,
IPPI_INTER_CUBIC2P_SUPER
but this is missing from the header files. Is this an oversight? what is the correct value of IPPI_INTER_CUBIC2P_SUPER. Is this mode to be supported in ResizeSqrPixel into the future?
I cannot use SuperSampling as a substitute as it is roi based instead of scale value based. The effect of pixel rounding in this way would cause artefacts given the way I am using the images.
Any suggestions?
Paul
Naveen_G_Intel
By mistake we have added this mode (IPPI_INTER_CUBIC2P_SUPER - supersampling interpolation) into the Manual, corrected in the upcoming release of IPP. It means we have removed it from the ippiman.pdf.
Naveen Gv
paullumidium_com
Hi Naveen,
Does this mean that you have removed the capacity to resize images using Super Sampling with identical scaling in the x and y directions? This is possible with the depricated Resize but not with the new SuperSample function.
To remove this feature would be a reduction in the capabilities of the library. If you are doing this please rethink as my use of ippi depends on it.
Paul
Naveen_G_Intel
Hi Paul,
No, there is Super Sampling method for the functions ippiResize, ippiResizeSqrPixel and ippiSuperSampling
IPPI_INTER_CUBIC2P_SUPER was an erratum
Naveen Gv
