Unable to link IPP with my program
prakrati
The makefile is as follows :
all:
IPPROOT=/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t
gcc ipp1.c -o ipp1.o -I$(IPPROOT)/include/ $(IPPROOT)/lib/libippmmergedem64t.a $(IPPROOT)/lib/libippmemergedem64t.a $(IPPROOT)/lib/libippiemergedem64t.a $(IPPROOT)/lib/libippsemergedem64t.a $(IPPROOT)/lib/libippimergedem64t.a $(IPPROOT)/lib/libippsmergedem64t.a $(IPPROOT)/lib/libirc.a $(IPPROOT)/lib/libsvml.a $(IPPROOT)/lib/libimf.a $(IPPROOT)/lib/libiomp5.a $(IPPROOT)/lib/libippcoreem64t.a -lm -lpthread
The error message is as follows :
/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t/lib/libippmemergedem64t.a(ippm00488.o)(.data+0x0): undefined reference to `mx_ippmAdd_mm_64f'
/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t/lib/libippmemergedem64t.a(ippm00488.o)(.data+0x8): undefined reference to `m7_ippmAdd_mm_64f'
/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t/lib/libippmemergedem64t.a(ippm00488.o)(.data+0x10): undefined reference to `u8_ippmAdd_mm_64f'
/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t/lib/libippmemergedem64t.a(ippm00488.o)(.data+0x18): undefined reference to `y8_ippmAdd_mm_64f'
/homenc/iyaesa4/intel/ipp/6.1.2.051/em64t/lib/libippmemergedem64t.a(ippm00488.o)(.data+0x20): undefined reference to `e9_ippmAdd_mm_64f'
collect2: ld returned 1 exit status
make: *** [all] Error 1
I am using the method 'ippmAdd_mm_64f' for marix-matrix addition.
Kindly help me on this.
Thanks & Regards.
Vladimir_Dudnik
as far as I know the order of libraries in linker command line does matter for Linux linker. So I would suggest you to change the order of ippm libraries - please try to set first libippmemerged.a and set libippmmerged.a as a second library.
Vladimir
prakrati
Hello
I tried with all kind of orders but with no success .Please help me
Pavel_B_Intel1
Hi prakrati!
"emerged" library have to set before corresponded "merged" library, please try this line:
gcc ipp1.c -o ipp1.o -I$(IPPROOT)/include/ $(IPPROOT)/lib/libippmemergedem64t.a $(IPPROOT)/lib/libippmmergedem64t.a $(IPPROOT)/lib/libippiemergedem64t.a $(IPPROOT)/lib/libippimergedem64t.a $(IPPROOT)/lib/libippsemergedem64t.a $(IPPROOT)/lib/libippsmergedem64t.a $(IPPROOT)/lib/libirc.a $(IPPROOT)/lib/libsvml.a $(IPPROOT)/lib/libimf.a $(IPPROOT)/lib/libiomp5.a $(IPPROOT)/lib/libippcoreem64t.a -lm -lpthread
It should work
Pavel
Naveen_G_Intel
Pavel is right, we are also mentioned same in the Simplified Link Instructions for the IPP Library article.
the order of the link list is important for static libraries in a Linux environment, since many of the linkers used in this environment default to operating in a single-pass mode. In this case it is best to order the library files according to the following rule: *emerged.a first, followed by *merged.a and ending with ippcore.a.
Naveen Gv
