Unexpected Error for ippiFloodFill_Range4Con_8u_C1IR
Bock__Thomas
I'm using the function  ippiFloodFill_Range4Con_8u_C1IR like in the example code below and the function returns -5 for status. This value is not in the documentation as return value  and I don't understand why any argument should be bad?
Can anybody help me?
Thank you!
#define ippStsBadArgErr -5 /* Incorrect arg/param of the function. */
IppStatus status;
Ipp8u buffer [] = {
0, 0, 0, 0, 0,
0, 128, 128, 128, 0,
0, 128, 127, 128, 0,
0, 0, 0, 0, 0
int nBufSize(0);
status = ippiFloodFillGetSize_Grad(IppiSize{ 5,5 }, &nBufSize);
Ipp8u* tmpBuffer;
tmpBuffer = ippsMalloc_8u(nBufSize);
IppiConnectedComp region;
status = ippiFloodFill_Range4Con_8u_C1IR(buffer, 5, IppiSize{ 5,5 }, { 2, 2 }, 170, 43, 43, &region, tmpBuffer);
Gennady_F_Intel
therefore, please check if all input parameters are correct.
regarding documentation - we will add this return values for this function.
Bock__Thomas
I've found that everytime the newVal is between [seed value - minDelta; seed value + maxDelta] status - 5 is returned. Why this is not allowed? The topic isn't really new, I found that it was discussed in 2013, but without any result...
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/429856
Pavel_B_Intel1
Hi Thomas,
thank you, we will investigate it and answer you during ~1-2 weeks.
Pavel
Gennady_F_Intel
Thomas,
the fix of this issue available in IPP v.2020 which has been released a few weeks ago. Could you try to check how this function works on your side and let us know the result!
Thanks, Gennady
