6847 Discussions
Using ipps in Visual Basic 2005 and .NET in general
albusmw
Hello!
I would like to use the Intel IPP within my Visual Basic 2005 projects.
I am not able to call any function as I do not know how to generate the IntPtr to my floating point arrays.
If anybody could e.g. show me how to use the ippsAdd_64ffunction to add2 10-element vectors, I would be very glad ...
Martin.
Vladimir_Dudnik
Hi Martin,
You can take a look on IPP VB sample, available on IPP Samples pagelook at Development Environment section.
Vladimir
albusmw
Hello, Vladimir,
thanks for your fast reply. The problem is that all examples are based on the ippi function where the pointer IntPtr to the data can be obtained by the special function Scan0.
Within e.g. a floating point vector, I don't know how to get the pointer to that floating point vector.
If you could just add the correct line in the following code, I would be very happy:
Dim
X() As Single = {1, 2, 3, -4, -5}
Dim I_Ptr As
IntPtr = ?????
ipp.sp.ippsAbs_32f_I(I_Ptr, 5)
Martin.
Vladimir_Dudnik
Hello Martin,
our expert suggest you to use the following piece of code:
Dim X() As Single = {1, 2, 3, -4, -5}
Dim I_Ptr As IntPtr = Marshal.UnsafeAddrOfPinnedArrayElement(X, 0)
Vladimir
albusmw
Hi!
Thanks for the help, this did solve some problem.
Could you please tell me how I get the IntPtr to one single value, e.g. to use the ippsMax function? At the moment, I do it the way you can see below which is not very elegant. (I write a wrapper around the IPP function to give a more conveniant access to them).
By the way, is there any plan by Intel to provide such a wrapper which uses e.g. function overloading, ... to provide such an easy access?
Martin.
Public Function ippsMax(ByRef Array() As Single, ByRef Max As Single) As ipp.IppStatus
Dim RetVal As ipp.IppStatus : Dim TempVal(0 To 0) As Single
RetVal = ipp.sp.ippsMax_16s(GetPtr(Array), Array.Length, GetPtr(TempVal))
Max = TempVal(0) :
Return RetVal
End Function
Public
Function GetPtr(ByRef Array() As Single) As IntPtr
Return System.Runtime.InteropServices.Marshal.UnsafeAddrOfPinnedArrayElement(Array, 0)
End Function
Vladimir_Dudnik
there is answer from our expert:
you need to useShortfor 16-bit data notSingle. the one of the reason why we deliver VB wrapper sample as a sample, not a complete solution is that you can implement it in different ways. You can change in sample sources for functions like ippsMax the following:
Declare
Function _
ippsMax_16s
Lib "ipps-5.2.dll" _
ByVal pSrc As IntPtr, ByVal len As Integer, ByRef pMax As Short) As IppStatus
and then in your example
Public
Function ippsMax(ByRef Array() As Short, ByRef Max As Short) As ipp.IppStatus
RetVal = ippsMax_16s(GetPtr(Array), Array.Length, Max)
Return RetVal
End
Function
Public Function GetPtr(ByRef Array() As Short) As IntPtr
End Function
Vladimir
