Vector Multiply and Matrix
Derek_Woodman
I am looking for an IPP function that can help me accomplished the following task:
I have a small array, call it a window. I also have an image represented as an array like all ippi functions use. I want to move the window through the array and for each pixel mutliply the window by the pixel and the few surrounding it. I then want that pixel value to take the sum of all the multiplication that was just done. Then move on to the next pixel in the image.
I found all the filter function in ippi. There is a max window function that moves a window through the image and sets each pixel to highest pixel value in the window. I want to pretty much do the same thing, but mutliply all these values everytime by the window and then sum the window.
I can accomplish this with the matrix multiply and moving my own window through the image, but I'm just checking to see if there is a function for this since it will probably be more optimized.
Thanks!
Andrey_B_Intel
Hi, Derek.
Could you provide reference code of your algorithm to understand if it is possible to use ippiFilter_32f_C1R function?
Derek_Woodman
Andrey,
That function worked perfectly. Thank you!
Derek
