What algorithm was used for function ippiDFTFwd_RToPack_32f_C1R and what is the algorithm complexity?
Zhifei_X_
What algorithm was used for function ippiDFTFwd_RToPack_32f_C1R?
And what is the algorithm complexity? like the method in FFTW?
I tried to increase the image size for the ippiDFTFwd_RToPack_32f_C1R, the execution time is not monotone increasing (of couse, 2^n is of the minimum execution time). Is there any theory analysis of the algorithm complexity for ippiDFTFwd_RToPack_32f_C1R? Many thanks!
SergeyKostrov
Valued Contributor II
>>...What algorithm was used for function ippiDFTFwd_RToPack_32f_C1R? Intel never releases details on internals of some API / algorithms and a generic answer could be as follows: a DFT-like algorithm is used. Please try to search for articles or application notes on Intel web-site related to DFT processing. Note: I checked my collection of Intel articles and I have these two: Split-Radix FFT.17649.pdf SSE in a Fast DCT Algorithm.40981.pdf
Zhifei_X_
Hi, Sergey, could you send me the articles? I tried to search but can not find the pdf files.
Many thanks!
Igor_A_Intel
IPP DFT is based on vector/image length/size decomposition on primes. Prime factors that have special code branches are 2,3,5,7,11,13. For powers of 2 (FFT) supported radixes are 2,4,8,16 (depends on architecture - radix-8 is supported on Intel64, radix-16 - on Xeon-Phi only). For lengths/sizes that can't be decomposed on these primes (or for reminder parts) - convolution based algorithm is used. In general case you may consider algorithm complexity as ~5*n*log2(n) arithmetic operations per 1 call (1D case, n==vector length).
Regards, Igor
SergeyKostrov
>>...could you send me the articles? I tried to search but can not find the pdf files. >> >>Split-Radix FFT.17649.pdf >>SSE in a Fast DCT Algorithm.40981.pdf Yes and I'll do it later today.
SergeyKostrov
>>>>...could you send me the articles? I tried to search but can not find the pdf files. >>>> >>>>Split-Radix FFT.17649.pdf >>>>SSE in a Fast DCT Algorithm.40981.pdf >> >>Yes and I'll do it later today. Here they are.
SergeyKostrov
>>>>Split-Radix FFT.17649.pdf Here is a zip-file with sources.
