6814 Discussions
What are the supported window sizes for MinEigenValGetSize?
Intel_C_Intel
Dear support:
I am putting together some functions from IPPI/Computer Vision in order to detect some corners using the KLT corner detector.
When using the MinEigenValGetSize to find the buffer size needed by MinEigenVal,it seems that the only supported sizes for avgWindow are 1,3,5,7. Is that true? If you try size 9, for instance, you get an error code.
This avgWindow is increased on corner detector algorithms to avoid getting two points where there should be one. If it really doesn't support big windows sizes, I won't be able to use the function even for 320x240 resolution images
(see attached file, corner is deteceted in red). If anybody has any workaround for this problem please reply.
Ps.
Couldn't post that on the premier support, it isn't working.
Message Edited by juliano.camargo@haptica.com on 02-02-2004 08:15 AM
Message Edited by juliano.camargo@haptica.com on 02-02-2004 08:17 AM
Message Edited by juliano.camargo@haptica.com on 02-02-2004 08:18 AM
Intel_C_Intel
the attachment:
Intel_C_Intel
the attachmnt:
Ying_S_Intel
I noticed that you have successfully submitted this issue to Intel Premier Support.
Ying
Message Edited by ysong on 02-05-2004 10:05 PM
