6825 Discussions
Why is the modulo time base becoming 1 two times consecutively with MPEG4 encoder with B-frames enabled ?
rramani80
Hi there,
I am using the MPEG4 encoder with B-frames option.
Encoder parameters
Time resolution : 5
Time increment : 1
The modulo time base value in the VOP header becomes 1 two times consecutively, when VOP time becomes equal and one greater then the time resolution 5.
I am not sure whether this is correct because I don't see this in MPEG4 streams generated by soft IP phones.
Please let me know what you guys think about this.
Ram
