csharp sample code for JPEG2000
Predrag_Ostojic
Where can I find some C# examples for JPEG2000 codec. If not available can I get at least C++ examples?
Naveen_G_Intel
JPEG 2K sample code is part of IPP main sample package refer to folder: IPP-samples/image-codecs/uic/src/codec/image/jpeg2000
C #wrappers for image processing functions are part of language-interface.
Naveen Gv
Predrag_Ostojic
Hi Naveen,
Thanks for the answer.
I saw the C# wrappers but I have no idea how to use them, i.e. sequence of calls, proper parameters, ...
My use case isquite simple: take an inputstream/buffer of the JPEG2000 encoded image and decompress it to the output stream/buffer and vice versa.
The example that you refer to is fairly high level, it makes use of theOwnJP2Decoder/OwnJPEG2000Decoder and OwnJP2Encoder classes.Unless Ihave those classes I cannot see the actual sequence of calls oftheIPP interfaces.
For me, the best would be to have C#/C++ examples but some documentation or pseudo code (referring to IPP interfaces)that explains how to implement my use case would suffice.
If I can get hold on the source code for OwnJP2Decoder and OwnJP2Encoder classes I would probablybe able to figure out how to implement equivalent codein C#.
Predrag
