6832 Discussions
simple_player compiled on _IPP_SEQUENTIAL_STATIC not runable on seperate windows machine independently
TatKin_T_Intel
hi,
i have downloaded the IPP sample simple_player and compiled successfully and run from my build machine perfectly. i can see playback via simple_player. my IPP is version 7.0.2.048.
when i compiled from my build machine, the initial default setting for MANIFEST->GenerateManifest is "no". when i execute the simple_player program there is an error message stating :
"The program can't start because MSVCR90D.dll" is missing from your computer. Try reinstalling the program to fix this problem"
i managed to fix this problem by turning GenerateManifest to "Yes". and i can run simple_player with a playback on my screen. this only happened all in my current build machine.
now, when i transfer this simple_player.exe program to another windows machine, and i tried to run the program, the program just wont run at all.
i read before from IPP knowledge page that it is something to do with _IPP_SEQUENTIAL_STATIC Preprocessor has to be added during compilation and i did add this so that all the independent libraries are added into the executable and so that this program can be executed in a seperate machine.
in this event, i cannot run the simple_player.exe on seperate machine.
however, if i install the machine to have VisualStudio2008, and install with IPP, i m able to run the simple_player.
my question is, how can i build a simple_player.exe that has been linking all libraries and then being able to execute independently?
thanks.
Naveen_G_Intel
Hi Tat Kin,
To execute simple_player independently you have to use one of the following option.
If you build with bash file, In the audio-video-codecs\Makefile, change
LINKAGE = dynamic
to:
LINKAGE = static
If you built with VC project file, in the simple_player property>>C/C++>>Preprocessor>>
Change:
_IPP_SEQUENTIAL_DYNAMIC
to:
Looks like you are already using 2nd option, what are the error you are getting while running it on another machine?
Naveen Gv
TatKin_T_Intel
Hello Naveen,
you are right i had already added the _IPP_SEQUENTIAL_STATIC into the compiling process via VS.
here is the error i found while attempting to run simple_player. it basically just wont run.
log:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Demo Depot>cd Desktop
C:\Documents and Settings\Demo Depot\Desktop>simple_player.exe "Taipei101+sunset+WMV+HD+720.mp4"
The system cannot execute the specified program.
C:\Documents and Settings\Demo Depot\Desktop>simple_player.exe "Taipei101+sunset+WMV+HD+720.mp4" -vd
x
