error : IPP Threaded static libraries are not installed
www_q_
I have a problem with the IPP, I use alot of IPP functions in one of my C++ programs just to benchmark IPP against other performance libraries, and when I try to compile the program, it always report a failiure with the following messenage: "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Platforms\x64\PlatformToolsets\Intel C++ Compiler XE 13.0\ImportBefore\Intel.Libs.IPP.Intel C++ Compiler XE 13.0.targets(87,5): error : IPP Threaded static libraries are not installed" My liscence is a free 30-day trial liscence of Intel Parrallel studio 2013 XE (the liscence has not expired), and my program is compiled with "shared-DLL" method in the IPP selection box in the propery manager, not any threaded static libraries methods, but when I try to build solutions with Intel C++ compiler, it always abort with the above error messeger, can anyone tell me how can I fix this?
Chao_Y_Intel
Hello, In the IPP 7.1, threaded static libraries are separate download now. You can login into the registration center to the get these libraries: https://registrationcenter.intel.com/regcenter/register.aspx Thanks, Chao
www_q_
Thanks, but I know that. Like I said, I have already disabled threaded-static library in the property manager (I selected shared-dll there instead), yet the intel compiler still ask me for the threaded static libraries. I just want to know is there any commmand line options to switch this off to allow the compiler build the program properly without threaded static library being installed, many thanks.
www_q_
