I am having a hard time using the function erode. It constantly delivers the error stride value is less than the row length. I am using IPP 6.0.1.071 on ubuntu linux.
What can be causing this? This code is almost identical to the example in the documentation. I also tried Erode3x3 and the in-place variant with no success.
Is this a bug or am I doing something wrong here?? Please take a look at the code here below.
best regards,
Saevar
best regards,
Saevar
[bash]#includeint main(){ IppiSize roiSize = {7,7}; Ipp8u pMask[3*3] = {1,1,1,
1,1,1, 1,1,1}; IppiSize maskSize = {3,3}; IppiPoint anchor = {1,1}; Ipp8u pSrc[7*7] = {0,0,0,0,0,0,0, 0,0,0,1,0,0,0, 0,0,1,1,1,0,0, 0,1,1,1,1,1,0, 0,0,1,1,1,0,0, 0,0,0,1,0,0,0, 0,0,0,0,0,0,0}; int srcStep = 7; int dstStep = 7; Ipp8u pDst[7*7]; int dstSize = 7;
IppStatus thestatus = ippiErode_8u_C1R(pSrc,srcStep,pDst,dstStep,roiSize,pMask,maskSize,anchor);
printf(ippGetStatusString(thestatus)); return 1; }[/bash]
I found out the problem. It was a border-problem, that is, I needed to copy the image to a slightly larger image with borders. That way, I can apply erode, or any other function that uses neighbouring pixels.
That's right. We're glad you find solution.
Vladimir
Vladimir
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
Topic Options
