h264 encoder problem
gossamer
I'm using umc_video_enc_con from IPP 6.0. Trying to encode YV12 raw video to h264, but i have some problems ... As YV12 is YUV 4:2:0 but with YVU order i'm using proper color format (YV12 or mColorFormat=0), result is the same as using standard YUV420 color format (and that is blueish video).
start application with: umc_video_enc_con h264 -i input.yuv -f60 -w 1280 -h 720 -o out.h264
Also i have changed video_enc_con.cpp to use mColorFormat as YV12.
Do i need to change anything else ? Is YVU420 supported ?
Thanx!
Emmanuel_W_
Quoting - gossamer
Thanx!
Check the VideoEncodingSample::GetInputData function in video_enc_utils.cpp. This is where the plane are inverted for YV12. In order for the plane switching to happen, the colorformat must be set correctly in the MediaData object. I believe this is done in the Run() method. You should check if the colorformat has the proper value there.
