ipp BGR32 to YUV420, Lost Color
Guojiangli
void BGRA2NV12(const unsigned char I[], const int image_width, const int image_height, unsigned char J[])
IppStatus ipp_status;
int srcStep = image_width * 4;
int dstYStep = image_width;
int dstCbCrStep = image_width;
IppiSize roiSize = { image_width, image_height };
const Ipp8u* psrc=(Ipp8u*)I;
Ipp8u* pDstY = (Ipp8u*)J; //Y color plane is the first image_width*image_height pixels of J.
Ipp8u* pDstCbCr = (Ipp8u*)&J[image_width * image_height]; //In NV12 format, UV plane starts below Y.
Ipp8u* pDstV = (Ipp8u*)&J[image_width * image_height * 3 / 2];
//unsigned char * pDst[3] = { pDstY, pDstCbCr, pDstV };
unsigned char* pDst[3] = { pDstY, pDstCbCr, pDstV };
int dstStep[3] = { image_width, image_width / 2, image_width / 2 };
ipp_status = ippiBGRToYCbCr420_8u_AC4P3R((Ipp8u*)pSrc, srcStep, (Ipp8u**)pDst, dstStep, roiSize);
#if 0
if (ipp_status != ippStsNoErr)
memset(J, 128, image_width * image_height * 3 / 2);
#endif
Use this function to compare the original image with the output image during image conversion. It is found that the output image, red is lost. Is it written in the wrong way? How to solve it?
AbhishekD_Intel
We are forwarding this issue to the SME.
Warm Regards,
Abhishek
Abhinav_S_Intel
The function BGRToYUV420 uses the same formulas as the function ippiRGBToYUV does. Can you please refer and verify the formulas mentioned here in this example?
https://software.intel.com/content/www/us/en/develop/documentation/ipp-dev-reference/top/volume-2-image-processing/image-color-conversion/color-model-conversion/rgbtoyuv.html
