ippiResize
Joseph_T_
Hi, I am new to the IPP. Can the ippiResize method be used on encoded h264 frames? Or is it used exclusively for uncompressed images such as RGBA?
Joe Tomczyk
Roman_T_
ippi library works only with individual images. Encoded H264 means that you have 1 I-image and some P-images inside H264 GOP. So to make something with P-image (resize for example) you will need data from I-image.
So you will not be able to resize encoded H264 frames until you decompress them.
Roman
